I don't have the stock handlebar for the V20. After riding my S40, I decided I like that handlebar better, so I asked Robert at CB if I could order an S40 handlebar for my V20. They didn't have any in stock, but recommended the Salsa Woodchipper II bar. It's widest configuration is 1 mm narrower than the S40 bar. I put that on my V20 and was very happy.
I use Ultegra DI2 components with brifters and rim brakes on my V20. I have HY/RD on my S40. I actually prefer the rim brakes.
I like your idea of moving the handlebar clamp forward. It seems you can make a lot of space to get out of the bike Are you using the Crononero Basebar:
or the Low Rider Basebar?
In either case, with the ends pointing up, I don't understand how you hold onto the bars. Seems like the bar ends would get in the way and the angle of the bars coming toward you would not be a very good angle for hold the bar. Also, the max bar width is 44 cm. The standard S20 bar is 47 cm, so the Crononero is a bit narrower, which may work fine depending on how you angle it. Do you have a picture you could share?
I searched all morning for handlebars. They really don't design anything that would be optimal for Cruzbikes, especially the V20, S40, where you need to push/pull while riding.
