hamishbarker
I do enjoy my vendetta, and don't ride it nearly enough to justify thinking about how it could be a more efficient bike. Nevertheless, I keep having ideas about how to improve on the vendetta. I don't have enough spare time or skills to execute them, but thought they might entertain the denizens of the forum.
From least to most radical
1. Simplify and lighten the rear frame (from headset to rear dropouts).
The rear frame of the vendetta carries only gravity loads and perhaps a little torsion as the rider's hips perhaps push on alternate sides of the seat back. But the latter must be very minimal if the seat back can be secured with only velcro. Flex of the rear frame doesn't matter for the drivetrain. At certain road vibration modes, undamped springyness might be a problem, but I wonder if making the rear frame lighter and design for strength to weight ( not stiffness) might shave some grams. I have not weighed the rear part of my vendetta to see if the scope for weight reductions are too small to be worth it. Has anyone? Change of material to CFRP in an appropriate frame shape might also assist with such strength/weight optimisation.
2. Aerodynamic declutter of the front triangle.
The front end of the vendetta sees the full airflow with no shielding by the rider or wheels. There are two pairs of lower members (fork blades/ chainstays) plus the boom, plus the drivetrain. All making frontal area. Drivetrain frontal area can't really be reduced (except perhaps by a fairing over them, but that would probably just make for more frontal area, so not a help). I can see how Di2 shifting and cable elimination might be a good thing. Anything else?
3. change the seat design to eliminate the flanges on the seat pan (not on the seat back) because they probably make more drag than a smooth seat edge.
4. Mono stay front and/or rear stays.
Eliminate the multiple members below the fork crown and BB. Replace them with a single, monoblade from the BB to the front hub. Make the front hub run on a cantilevered axle (i.e. no left fork blade or left chainstay). Integrate the monoblade with the big boom. Support from the fork crown to midway along the big boom with a simple thin, short strut which is faired to the front of the head tube. Change the rear wheel to single sided monoblade fork also and cantilevered hub. Drum brakes on both hubs. The front forks and chainstays would be replaced by a single monoblade, while the rear four members (two "chainstays" and two seatstays) would be replaced by a single monoblade. The bike could be much lower drag, although option 4's cantilevered hubs, drum brakes and monoblade forks would be heavier. I need to make a sketch to post here for comment.
Anyone else got ideas for improvements to the V (or a V inspired homebuild?)
