Ventisit for the S40 – which one to choose?
Damien
Hello. I'm a bit confused – which Ventisit should I choose for the S40? I'm looking at this one:
81x26/18/22 cm Cruzbike (SKU 1281) and after measuring my setup, it turns out that this model is at least 10 cm too long for me (I'm short).
So here's my question – which Ventisit do you have, and which one is sold on the Cruzbike website as the one for the S40?
Also, has anyone tried fitting a Ventisit to the standard neck rest? 15x10 cm Neck pad I'm considering it.
Please share your experiences!
Best regards"
IyhelM
This one seems to be shorter and designed for the new adjustable seat.
Regarding neck rest, on my S2.2 I finally removed the Cruzbike one and fitted a ICE one that works much better for me, I don’t need additional padding on it.
roadhog
Best regards"
Hello,
My pad is 76x26x18x22cm I have a Ventsit neck rest. But i don't use any neck rest at all. I also removed the seat extension.
Mascottrepair
Hey Damien! I totally get the sizing struggle ,I'm on the shorter side too! I went with a trimmed Ventisit for a better fit on my S40 one time. The one Cruzbike lists is that longer SKU, but it’s easy to cut down. And yes, the Ventisit pad works great on the stock neck rest with a little tweaking—super comfy once it’s dialed in!
BentAxel004
Best regards"
My S40 did not have a Ventist seat installed. The from the factory was much more shock absorbing. (Thicker padding in the seat area. Having said that, if you go to the Ventist website, they many sizes to choose from. I purchased a headrest from Ventist for my V20c but have not added that type headrest to my S40. I did install a Cruzbike headrest with the st kick pad on the S40. However, I find I am not using the headrest much. Just my personal preference. Poe you can find a seat pad that will work on your bike. Have you measured the stock Ventist seat pad for the V20? The Ventist pad I purchased for my Thor seat pad is longer that the stock pad. Without specifics it’s hard to answer your question.
