I’m looking to get a smart trainer to maintain my Cruzbike fitness through the winter. I understand the differences and relative merits of wheel-on vs direct drive for diamond frame bikes but was wondering is it the same when mounting an S40? Should I go for the wahoo Snap (wheel on) or the wahoo Core (direct drive)? Your comments/advice would be greatly appreciated.
ps I use TrainerRoad and have a Wattbike for my main cycle training and the big efforts, this additional smart trainer is to ensure I don’t lose my recumbent fitness over the winter.
Hi,
I have tried both on my S40. I currently own a Wahoo SNAP acquired secondhand. The core was briefly borrowed from a friend to compare the power numbers. They both work as expected. However, if you can afford the Core, I strongly recommend it.
The KickR Snap has some problems.
1. The power accuracy drifts(compared to my crank power meter) as the workout progresses. (I think it does not have temperature compensation). Mine starts within 3% of my power meter readings. Then it gradually drifts to +10% (+20 to 30watts)off after 30 minutes of riding. Probably my unit is faulty. It's frustrating as it gets harder and harder to stay in the correct zone.
2. You need to perform spindown calibration before every ride. Which should be preceeded by a 10 minutes warm-up.
3. Your tire pressure must be constistently topped up otherwise it can slip or give noticeably inaccurate power readings.
4. The quality control of the build is wanting. The unit can make some strange ratling noises sometimes. (Probably becuase mine was secondhand) .
5. It wears out the tire unless you get the trainer specific one
As a workaround I use it inconjunction with my crank based power meter (Using power matching in TrainingPeaks and Zwift). This way, KckR SNAP does the ERG mode and SIM modes beautifully.
The KickR Core Direct drive, on the other hand, was super! The power numbers were consistently within 2% of my crankbased power meter. Very quiet and smooth rolling throught out the session.
Below is a Dual Power Recording(in IndieVelo/TPvirt) for the SNAP. You can see the power drifting.
