Which sofrider?
handsofstone
After a considerable amount of searching, I have decided to buy a Sofrider, but I need advice to decide whether to go with the 8-speed or 16-speed? Anything that you could volunteer to enlighten me would be greatly appreciated.
Hi,
The V2 Sofrider is offered with a 16 speed drivetrain. There may be some V1 8-speed Sofriders available.
The V2 was improved in many ways, not just by adding a front derailleur and a double crankset.
I don't know if you've seen this:
http://www.cruzbike.com/SofriderV2-DougBurton.pdf
or this:
http://www.cruzbike.com/SofriderV2.1-Update.pdf
If you live in a hilly area, you will definately enjoy having the 16 speed drivetrain.
Best,
Doug
You don't mention what you currently ride or what you're really looking for. Depending on what you'd like as your end result, starting with the 8-speed Sofrider is a good move, since it can serve as an excellent base for a number of upgrading departures. Let's say you want a fast road bike. If you've already got one you can simply transfer your existing components & wheels over to the Sofrider frame. Failing that, you can upgrade incrementally, as funding permits.
Aside from a pair of 26 x 1 slicks, perhaps the easiest upgrade is installation of a double chainring. 1st, get a used double chainwheel set from ebay or Craig's List. This and a set of 5 chainring spacers (approx 1mm thick) bolt directly onto the existing crank in place of the 44T ring & chain protector. Just add a left hand shifter & front derailleur to complete the package. Of course, you could also just swap out the existing set of cranks for a triple, replace the shifters with a 3 x 9 setup & get a 9-speed cassette.
You may decide you'd like to upgrade to disk brakes. It's a bolt on at the front, since the mounting brackets are already there on the fork, just change the cable. Unfortunately, today, you'll need a custom adapter bracket at the rear. This may change shortly and be readily available aftermarket, making it more of a direct bolt-on upgrade. However, disk brakes allows for very quick wheel changes -- you could have a set of 700c rims for fast road riding & also a set of fat-tired 26 inch rims for touring. The Sofrider is quite versatile.
As Gromit discreetly reminded me, we are also offering the Sofrider V2.2 as an 8-speed bike.
I have been sufficiently immersed in Quest (suitcase packing instructions and assembly manual) that I completely forgot about the 8S V2.2.
That bike is a bargain.
Previous advice from all posters applies nicely...
Best,
Doug
