OK - I finally did it. I compared the XQL Q-ring to the regular Q-ring, to a regular round chain ring.
It was not exactly a one-to-one comparison as my XQL Q-ring is 53, my regular Q-ring is 52, and my circular one is only 50, but I adjusted cog teeth and rpm to make speeds match.
Variable Factors:
Procedure:
I started my Garmin 510 and did some warmup.
I had the XQL rings on OCP #1 setting, and rode in the 19 tooth cassette cog.
I ran 2 x 1 mile tests.
First I ramped up to 100 rpm and then hit the lap button.
First mile was with hands out on hoods, then hit the lap button after 1 mile over and immediately brought my hands into the center of the handlebars, after exactly another mile, I hit the lap button again, and rode around the track to where my tools were.
I paused the timer, and then un-bolted the Q-rings and moved them to the next setting (i.e., #2, #3. #4, then #5)
Got back on the bike, started the timer and ramped up to 100 rpm again, then hit lap timer again..
I repeated each 2x1 mile tests (hands out 1st mile, then hands in 2nd mile), always making sure I was back up to and maintaining close to 100rpm before I hit the lap button for each 1 Mile test.
Once I ran through OCP settings 1 thru 5 on the XQL Q-rings, I switched them out for the regular ones and started over again on OCP #1 setting.
I did the exact same series with the regular Q-rings as I did for the XQL Q-rings, I did need to increase my cadence to about 102 (to get the same speed) since the regular Q-rings are 52 tooth, and not 53 like the XQL Q-rings
Then when I was done with the regular Q-rings 9OCP #1-#5), I switched them out for a regular round 50 tooth ring.
Since this ring had less teeth, I shifted to the next smaller cassette cog of 17. My speed was a little higher, so I reduced the cadence to about 98 to get close to the same speed of about 22 mph.
I ran one 2x1 mile tests on with this regular 50 tooth ring. (one hand out, one hands in)
Then just for fun I shifted down one more cog to 15 teeth and ramped back up to 100 rpm -- speed ~ 26.0 mph.
I ran one more 2x1 mile set of tests at this speed as well. (one hand out, one hands in)
Then to cool down I ran 1x1 mile test at about 9 0rpm on the 15 tooth cog (~23.5 mph) - hands out only
Then 1x1 mile at about 80 rpm on the 15 tooth cog (~21.0 mph) - hand out only
I transferred all the Garmin data into a google docs spreadsheet and hid all the "laps" that were in-between the ones I cared about.
OK - for the big surprise
Per Q-ring documentation: going to a "lower" OCP setting is supposed to give you a "higher" flat-lander speed. I found the opposite was true.
Also per documentation: a higher OCP setting with help you spin up faster - I did notice this.
Maybe it is just the way I ride (or maybe I have not developed enough strength to take advantage of the XQL rings), but I have not found the XQL rings to be any better.
On the contrary, I can go faster on less wattage on the regular Q-rings. I also appear to use less wattage to maintain the same speed as I increased the OCP # (although #2 did beat out #5 by 0.01, but this was contrary to all other data)
The other really interesting tidbit of data is that as the speed and cadence I was riding at; the regular circular rings out-performed the XQL Q-rings in every OCP setting, and out performed the regular Q-rings in every setting except OCP #5.
I also noticed it was easier to apply power through the entire pedal stroke on the circular rings when compared to the Q-rings.
These results are almost exactly opposite of what I expected and I am baffled beyond words!!!
I need to go back to square one and make sure now that I have the Q-rings mounted correctly, but I am relatively sure I am set up the same as Ratz, Rick, and Gary.
I would love for others of you to undertake the same testing so we can compare results. Please do, and submit your results to this thread.
I have uploaded a snapshot of some of my data. If you would like me to share the entire goggle docs spreadsheet with you, email me and I will share it with you.
Thanks,
Larry Oslund
Variable Factors:
- Completed on a high school track
- wind was zero or less than 5mph
- temperature: mid 50's F
- humidity: 90=% - even spit rain at me about 75% through my testing
- bike: V20
- cranks:Apex 140mm
- seat: older V2 seat, with Ventist pad
- wheels: 3-spoke CF
- tires: Conti 4000SII
- tubes: Conti race light
- Cassette Cog: 19 tooth for both Q-rings, but 17 & then 15 for regular round ring
Procedure:
Thanks,
Larry Oslund
