Campag Veloce Silvio with OMM rack
Robert Stewart
I finally got around to taking some photos this afternoon, so here's my Silvio in all its glory (although the light wasn't great).
Robert Stewart
Here is the rack from different angles. It is a Cold Springs front rack:
http://www.oldmanmountain.com/Pages/RackPages/FrontRacks.html
I sourced it fron Carradice, who are the UK dealers for OMM gear.
Nanda H.
Very nice Robert!!! I can't tell from the photo's but are the cranks carbon???
John, great forum software, better then Brol I think. It crops the photo's down to a nice size and you can still enlarge them when desired :lol:
Made a little progress on my Silvio today, added the Ultegra brake only roadie levers, and the Dura Ace barcons shifters, and will post them on my site and likely upload'm here to :idea:
Nanda H. wrote: Very nice Robert!!! I can't tell from the photo's but are the cranks carbon???
Bitchin', let's see 'em!
Robert Stewart
Mark B wrote: Bravo!!! Nicely done, Robert! That looks real good, thanks for sharing!
Thanks Mark. I thought I had better get some pics up quickly as people are curious about the rack (I know I was). My LBS fitted it and had to bend the brackets a bit to get around the brakes, but it looks sweet now. :cool:
defjack wrote:
That looks good. Are you going clipless soon? It made a lot of difference to me. Jack
Thanks Jack. I do plan to go clipless soon yes, but I thought I'd start out with flats initially. I think the clipless path will make a big difference to me too. I plan to start commuting daily on this beast soon, but I really need to bring in the front triangle as it's too extended where you see it in the photos and this causes me to overstretch. It will all be good soon... :)
Thanks Nanda. No, the cranks are just the standard Veloce ones in the Infinite colour scheme as seen here:
http://www.campagnolo.com/jsp/en/groupsetdetail/item_guarRSTVel_catid_1.jsp
I bought a complete Veloce groupset specifically for the Silvio build, and the infinite finish looked ideal. :cool:
I agree. I already reduced all these photos down quite a bit before uploading, but the quality still looks OK zoomed in I think.
Rob
Robert Stewart
Yeah, load them up. You know it makes sense. :!: :) :cool:
Rob
Rob, or should I say Buffalo Seabass;
'Bout time you got caught up with some of those pictures you've been promising! ;) :lol:
Robert Stewart
Mark B wrote: Rob, or should I say Buffalo Seabass;
That's Dr Seabass these days actually. :lol:
Yeah, yeah I know. Maybe I should post on the group that I put the figs up over here... :?
*edit - done that*
Rob
Robert Stewart
Here are some pictures of the On-One Midge bars I recently had fitted. Details about the bars are given here:
http://www.cruzbike.com/forums/viewtopic.php?f=3&t=39
I will follow up there with my ongoing assessment of the bars, but my initial thoughts are that they are a big improvement over conventional bars on the Silvio (much like the WTB bars Brian fitted).
Robert Stewart
Hi Silvio fans,
In my ongoing search for Silvio commuting perfection, I just took the plunge and ordered a Radical Designs Allfa Medium Rack Bag:
http://www.radicaldesign.nl/en/products/recumbentbags/allfa_top_bags.php
It has a 20l capacity, weighs 520g, and includes two bottle holders. It is also (fairly) waterproof, and features foam padding to keep it in shape. Compared with my current single pannier solution, it's much lighter, and should improve both balance and aerodynamics (it might even act as a bit of a tail fairing). High visibility was another feature I was looking for, so I went for the yellow option as pictured. I just hope it fits...
Rob
Robert Stewart
I am using the Radical bag every day for my commute, and it's working just great. There is plenty of space, and I am getting good aero and good balance as I had hoped. The bag is also quiet, and retains its shape well. Overall I am very pleased with the purchase.
It did take me a while to work out how best to attach the bag, but I now have it sorted as these next images show. Basically, the bag has two loops with clips that protrude from the bottom surface, one at the front, the other at the back. What I do is to first feed these down through the slots in the top of the Cold Springs rack. Next they go out, before looping round to connect together on the outside. The front loop also goes around the rear suspension, as one of the images shows, helping to stop the bag sliding backwards. The loops are pretty tight, and the bag is held very firmly in place using this arrangement. There is an additional loop on the front of the bag that is designed to go over the seat on some recumbents. I don't use this (you can see it tied up on the images in the previous post). Anyway, on with the pictures:
Nice rack!! Is that OMM the rear or front model? Is it the Sherpa, Red Rock or Cold Springs model? It looks like the rear Sherpa? I'd like to try it.
Thanks.
Robert Stewart
Stevearino wrote: Nice rack!! Is that OMM the rear or front model? Is it the Sherpa, Red Rock or Cold Springs model? It looks like the rear Sherpa? I'd like to try it.
Thanks.
Hi Steve,
It's the Cold Springs front rack. I don't think the rear ones will fit.
As I said earlier in the thread, my LBS fitted it and had to bend the brackets a bit to get around the brakes, but it looks sweet now. :cool:
Rob
Robert Stewart
Here is my hydration solution. I took a 1 litre widemouthed lexan flask from Lifeventure:
http://www.lifeventure.co.uk/htm/cookware/lexan-flasks.html
To turn this into a hands-free hydration solution, I added a smartube:
http://www.bluedesert.co.il/smart_tube.html
This comes with alternative sized caps to fit various bottle and flask designs:
http://www.bluedesert.co.il/smartube_caps.html
I am using the 63 mm one. In the two pictures, you see the flask with the smartube in place, first on its own and then in one of the bottle holders on my radical bag. Snugly fitted in the other bottle holder is an old powerbar container holding a spare tube, a puncture repair kit, and a Topeak Alien II tool kit.
