What Compass tires were you running tubeless? Does selant work in tubes for you?
Bon Jon on TransAm Bike race. Two separate (huge) ruptures. 190 pound rider. 70 psi on rear with tubes both times. rated at 90 psi if I recall.
I have some success with sealant with tubes. If the puncture is BAD, the latex tube and sealant slows down the rate of air loss giving me plenty of time to stop. Often the air is still hissing when I stop. Then, I rotate the wheel to keep sealant coming out. Then, it seals. Add some more air. 3-4mm is about the largest to seal. Glass bits and pieces are no problem. Not perfect but Orange helps.
