some 92 BCD pics
I just finished putting my
Ultegra 6703 92 BCD triple on my Silvio. below are before and after pics of the modification to the sprocket.
The first picture is the crank as received. The tabs on the granny gear interfere with the bottom bracket clamp, preventing proper installation (and function) of the crank.
Note the little tab (circled) and arrow are lined up. Put them back together this way.
alt="tabs in place (before)"
The second picture is an "after" shot. There's about 1.5-2mm clearance between the shortened tab and the BB clamp and the crank is fully seated against the BB.
I cut the tabs off with a fine blade on a jigsaw. Then I cleaned it up with a sanding roll on the dremel.
alt="trimmed tab"
If you are happy with a 30 tooth granny, this is pretty easy. The downside is you have to buy an ultegra
6703 crank instead of a cheaper 105, tiagra, etc. I stress 6703 because the older 6603 is 74 BCD.
If you want smaller than 30 teeth, get a 74 BCD crank, and follow IOW's directions for trimming and offsetting in the posts above.
