HeyMikey
Hitting the Gateway Trail!
I tinker a lot on the bike...My objective for getting the curved slider was to bring the hands down closer in vertical alignment with the shoulders. I wanted to hide them within the frontal area of the shoulders eventually. I did not achieve that until I bought a cheap (but seemingly durable) 46 cm carbon fiber bullhorn bar as shown and used the shifter grips for hand positioning below the bar. The leg fit is tight and requires un-clipping in slow maneuvers. To raise the frontal area of the feet upward into the chest frontal area I went with a long chainstay. I am 6'2" with long legs and normal arms. This bullhorn bar setup puts my arms slightly bent, level with airflow, and on the front of the shifter covers. I don't push on the shifter covers, my hands wrap around the front. This position may generate too much arm extension for most. I like the upper body rigidity and my hands have grown strong enough to withstand a constant tension from the shoulders. I have low to average leg/lung power and this configuration (with a few other mods) is very slippery in all conditions (...except mountains), but especially fast in strong headwinds.
That's a real different set up. And you have no problem slipping in and out of the seat at stops, correct? How did you fab that front tire skirts/fender?
