Any suggestions for a part number for a replacement brake pad for the RideRever mechanical disk brake on an S40???
Can't seem to find a replacement for my S40 disk brake pads. Any suggestions or alternatives like SRAM/ Shimano pads that will work??
All the major brand pads are larger the RideRever pads, which don't have and Part numbers on them.
Thanks
Art
Art,
The Shimano style should work - note that "normal" brake pads have a thicker backing plate than the stock ones - so it might be the case that with the replacement pads you need to leave the "heat sink" (questionable if this even works) out and not use it. The thickness of most pad backing plates is the same as the stock pad backing plate plus the heat sink metal. If you use the heat sink with the thicker backed pads you won't be able to get the pads to clear the rotor properly.
  • Compatible with Shimano XTR BR-M9000,BR-M9020,BR-M987,BR-M988,BR-M985, XT BR-M8000,BR-M785, SLX BR-M7000,BR-M675,BR-M666, ALFINE BR-S700, DEORE BR-M615, BR-RS785, BR-R785, BR-CX75, BR-R515 and BR-R315; FSA K-Force DB-TX-9000 and Afterburner DB-TX-9150; Rever MCX1 Post Mount
Shimano G05S-RX​
SwissStop RS Organic​
