JonB
Hi
Today i attached a luggage rack in the back above the wheel, attaching just next to where the wheel is attached to the frame. Because the top of the rear wheel holder frame is so low, i made my own extensions using L shaped aluminium profiles. The other end i attached to the rear wheel frame holder just behind the spring, and from there up to the front part of the luggage rack. In order for the spring to still work and the buttom part of the top frame where the seat is attached to move up and down without hitting something the extension L shaped alu profiles are attached with a wider distance at the rack than at the spring.
I will try to remember to provide pictures tomorrow when it is daylight.
