I have long been thinking of the switching my Silvio 2.0 handlebars to a narrower drop style version. After tons of looking around and thinking of what I wanted I finally ordered a generic carbon handlebar from China for US$56. In 2 weeks, it arrived packed nicely if not humorously like this!
It weighs in at 238 g in its 44cm C-C size. This is a replica of the Zipp Vuka Sprint with the key differences being (a) I chose the one without Zipp logos (b) the internal cable routings are not as slick, and (c) the curvature around the stem clamp area is different. This last item (C) is essential because the clamp area on the Zipp is 50mm, whereas the Silvio's clamp is 60mm. The curvature on the Zipp Vuka Sprint begins too soon, whereas it JUST FITS on this replica.
It was quite a hassle to change the bars as I had to re-cut some housing, especially since these bars route the cables internally. This was a feature I really wanted so that the cables would be neat AND I can leave the top of the bar exposed in their carbon glory, rather than tape up the whole bar in an area where I don't even put my hands.
These bars are designed with an aerodynamic top, so they would only look good if you mount your handlebars in a similar orientation that a DF road bike would. If you have your brifters pointing up at a high angle then the aerodynamic curvature of the bar would like strange and the internal cable routing would look silly.
You can see that I cut off about 65mm from the drop bars. Later on, I'll comment that I could cut off another 10mm, but I figure less is more at first! A dremel tool with cutter and sander made this quick and simple work.
Here she is all taped up. I am 175cm tall and 70kg. I fit nicely in these 44cm C-C bars. I can't imagine any narrower otherwise my thumbs would contact my legs. I worried whether when shifting, whether the levers moving inward would contact my legs, but they did not.
What is a mild concern however, is that when I make a tight turn, the bar ends can contact my hip and/or my upper leg. This happens because my BB is high and my handlebars are low. I never heard anyone else make this comment, but it also occurred to me that most others have their handlebars higher. This issue never happened with the original handlebars because they flare out so much. I think it is manageable and with improved handling skill I will lean the bike more and need to turn handlebars less. If I hadn't cut the bars, the problem would be worse. I am considering taking off another 10mm as this may help.
On my brief test ride, the feel is quite different. I have yet to go on a longer ride. I am looking forward to having my arms in a narrower position, and the bike is a lot easier for me to store and move around in the tight spaces that I do this.
