Elective Surgery - is a success.
Ok so the bullhorn for Silvio 2 journey for me comes to and end here. The configuration is done and it works splendidly so far on the trainer.
Advantages to this configuration:
1) Follows in the footpath of the Cruzbike Bullhorns
2) Compensates for the higher boom angle on the Silvio
?3) Internal cable routing (as much as possible)
4) Finger tip controls in the areo position
Step (1) Modify the SRAM shifters following the Cruzbike lead as documented above.
Step (2) Modify the handle bars as follows:
These are Deda Crono Low Riders at 440mm wide. (420mm and 460mm are available). These are mostly only available in the UK. If you order them from there; expect about a 4 week delivery time. Universal Cycles in the U.S. does stock them, but not the 460mm version. They are inexpensive and really nicely made. The could use about 1-2cm more forward reach for a stock Silvio, but more on that in a bit.
The configuration is the one I showed previously
The first step for this; is to route the cables internal to the bars. That required drilling a hole into the stem clamp of the bars for the cables to exit. Two quick shots side by side with a power drill and then some patience with a good quality file; level me a nice clean opening with out any metal burs. (The Silvo touch-up paint is a match for the bars for scratch clean up. The Shifter wire runs through the bar and the cables for the brakes run through the holes that come fabricated into the bars. You can see here that I have traditional housing for inside the booms; and jagwire metal compression-less housing for the outside routings. In the following picture I have all the housing and CABLES installed with far more cable that I need. That made assembly easier; as I only had to fight with the bars and not the entire bike.
Next since the Silvio boom doesn't have an exit port like the Vendetta, I had to violate my boom. The tap in the picture is where my pivot clamp goes. My front boom has been shorted 4 inches so it does not come past the pivot clamp area. You can see the final opening in this picture. To make it I drilled 3 holes side by side and again worked the file; and then painted it. It doesn't look that pretty here but it's nice and smooth.
For ease of assemble I removed the boom from bike and assembled all the wiring off the bike. The opening show here is sufficient for two cables to exit in the middle of the length; and the other two to exit at the forward end of the hole.
With all the cable prepped I put the pivot clamp back into position; and then used temporary electrical tape to hold the four wires in perfect position to go through the pivot clamp and over the head stack. It's a tight fit with these metal cable and taping them make it simple to reinstall on the bike. I put the tape right over the top of the piece of tape I was using to mark the Pivot clamp location.
In the picture above you can see the cable are taped in place. Once the boom is on the bike the tape is removed. The tape you see in the following pictures; is my positional marker and it is not holding the wires.
At this point it was just a matter of connecting all the wires. Special care is required to keep the shifter cable tight during installation so that the modified center routing doesn't rub and damage the cables inside the shifters. Going slow was the only real compromise.
The external cable under the brake is a non issue once the bars are wrapped. Notice I have the brake mounted just a little lower than the end of the bar; this is by design and puts one of the power hand positions over the top of the brake and shifter and not under the brake where the wire is. After wrapping with tape there is a nice and comfortable hand grip at the end of the bar with two solid hand positions. No extra padding was needed; just careful figure-8 wrapping of the excellent cork tape that comes stock with the Silvio.
The rest of these photos are side by sides of the bullhorn Silvio next to my wife's Silvio build. Her's is built with Carbon bars; alla Ivan at the top of the this thread. Compared to mine bike, with stock bars, her "on hood" hand position was a full 3 inches lower than mine.
With the bull horns installed My hand position is just over 1 inch lower than hers. Basically I picked up the 60mm drop and a slightly lower rotation angle. The result is a perfect riding position for me; without an extension installed. (A 50mm extension could still be interesting; as I have plenty of clearance to spare for that. 100mm is too much for my body size).
Now I mentioned earlier that; the bars could be just a tag bit longer to get an optimum reach. If Cruzbike wanted to produce a bar with a bullhorn with a 60mm drop like these specifically for the Silvio, they would likely need a custom bar with about 40mm more forward reach; maybe a little more and let the customer shorten if needed.
For me I got lucky and the problem just went away. I have switched the seat pad to Ventisit Vendetta pad, the thin version. The different between that new seat pad and the stock one is about 25-40mm in thickness (hard to say how much the stock one compress). So sitting on the Ventisit my arms are perfectly extended just like all the Vendetta bullhorn photos and drawings.
I must say it's a supremely comfortable position and I can generate a lot power with arms assist on the trainer. I am really glad I did this project, I have the Vendetta like riding position that I was craving with the suspension I needed to tame the chip-seal roads and care for my next injury.
Thank you for the Inspiration Ivan, and sorry about hijacking the thread; I didn't expect it to be such a big project of trial and error.
Oh and as a photo foot note; this a family room trashed by this project
If you do that to your house; you might find that you have to calm the wife by building her one like this:
Or in her case; teach her to build it herself. I did the hack sawing and the derailleur tuning; she did all the rest. I would say that this photo sums up how we both feel about our new Bikes.
