I agree the method of drilling and adding a pin through the frame where you did is not ideal. I feel the CruzBike frames use a thicker alloy then is needed adding to their weight over DF bike but at the same time that also mean you probably won't have any issues with your mod. If the frame was as thin as most of the high end mtbs I've seen then you could expect the drilled holes to oblong over time with every shock load from lumpy roads.
Now if you were to weld in a hollow alloy shaft through frame you could then use a pin without any worry of deformity over time. Sadly welding alloy is hard to do for an amateur and we can't be proficient at everything.
I actually did do this as my first solution, but then changed to the molded delrin plastic solution instead.an intermediate solution would be to pressfit a bushing across.
Without a bushing, the axle that goes through the aluminum frame has to fit as tight as possible into the hole to reduce the wearing out of the hole.
And no screw threads where it touches the aluminum hole.
Disclaimer: No Ratz's Hammer where harmed in the making of this projectRick, as long as you needed Ratz's rubber mallet to force the hard delrin into the frame, then this is a solid solution as it spreads the load into the base as well as the sides.
Carbon fibre build nearing completion
The fork is made from seat stays from doner Carbon frame, epoxied into cut down doner Carbon fork, then drop outs epoxied to seat stay ends, wrapped all with a few layers of Carbon fibre sanding between applications.
Sorry about the quality of pics ,the derailier hanger is part of doner Carbon chain stay ,so just bolt on.
Wow! That's a seriously oversized boom! Must be quite rigid with serious power transfer. Are you going to trim and plug the hole at the bottom end of the boom?Nearly Spring here in oz , build nearly complete, I set myself a goal to have it ready by September , I'm a bit over building and winter, just want to go ride my bike!
View attachment 5418 View attachment 5419 I can't remember where I found this little orange beast but it looks carbon maybe ,way cool me thinks!
Is it just me or does his riding position look like he could generate some serious power .
Especially if he carried a smaller lunch box.
Looks great and light. How much does it weight? 9kg? 10kg?Yes , will have my light mounted in there eventually, front end is super stiff, and light ,boom is part of a failed carbon racing oar .
Nice work. I don't like that BB is lower than seat.Another 9.6Kg (21lb )Carbon MBB using a BMC frame by Marco Ruga! Seat recline angle looks like the mid 30s. Probably 35deg.
Blog (In Italian, may need google translate)
https://biciclettereclinate.blogspot.co.ke/2017/10/rev-bmc.html
I think he is quite a tall guy and probably didn't want to extend the chainstay length from the donor bike.Nice work. I don't like that BB is lower than seat.
