gannet
I recall someone exasperatedly noting that Aston Martin owners referred to their cars by the chassis number. Despite that, I should note that CBSV 065 arrived ( a bit out of order, 098 has turned up elsewhere?). Seeing I needed to be next to the computer to see the website, I cleared the desk and that's where the build began - so, I just started noting details, so here we go:
First impressions on opening the box... many little bits - scary! ( Looking at the assembly notes on website, this doesn't look too bad ).
The fork ( to my untrained eye) seems heavy-ish - a candidate for further development?
And - the Ti spring issue as noted - I have to take a file to my Silvio? ( visions of Barbarians sacking Rome, the slashing of Rembrandt's "Night Watch" !!),
After finding a delicate file, and much angst, I scribe and file as instructed... it is bed time....
... in the warm soft light of day the filing still looks neat and nicely radiused, but needs a bit more on one side...
So, what about similar relief on the other end of spring?
There doesn't seem enough 'meat' on here to start filing - and I certainly don't want to mess with the frame - at least its not a sharp edge, so I'll hope it's OK. I ever so slightly chamfer both the alloy retainer caps.
The blue stuff - threadlock. How long does it last, I wonder, given nearly 3 years since manufacture. And for those screws I had to remove to do the spring it has flaked quite a bit. I use some 222 Loctite, hoping this doesn't work against the blue stuff.
(Soundtrack to the build:
Cuban Jazz piano is 'it' at the moment
Bebo and Chucho Valdez ( together and separately)
Harold Lopez Nussa ( why is his brilliant first album, 'Sobre el Atelier' so hard to find))
Next the elastomer rear spring. The notes show the elastomer rear 'spring' as already fixed to frame - mine is not ?! ( email query, quick response) There is a a short black threaded rod to screw into the frame, the black elastomer block pushes over it. Yes, the rod is here, goodo.
This looks like it will barely allow 1/2 of wheel travel before the end of the rod hits the alloy retaining cap on the spring. Hmmm... gingerly I cut about a 1/4" off the rod and screw it in again, slide on the elastomer.....
(phew, this is hard work - and I'll need to get the camera out) More later.....
