Many continued thanks to John and Doug for their almost immediate response to my tech questions regarding the building of my V2/K kit. These guys are amazing!
Other than installing the FD, I had completed the build. Unfortunately there was chain interference between the bottom of the bracket and the cassette.
John offered the following solution: "I suggest move the axle forward a little to allow clearance of the chain and the bracket when on the smallest cog."
The following pic will reflect the slight change in the axle position that resolved this issue. At John's suggestion I moved it a tad from the center of the opening which then created adequate clearance between the cassette and bracket for the chain to move smoothly with the FD movement.
