I sit because it is more comfortable. If you aren't pedaling sit down find shade kinda thing. You dont have to sit. Stand beside the bike. You dont need the lock out derailleur. Move the chain off the front sprocket. It will give the exact same result. Using a dry type lubricant is beneficial but I guess that applies to all techniques. The real benefit is with the bike on its side it doesn't create the balance, movement, fork separation thing while the chain routing is obvious. When I try it upside down the chain routing is a jig saw puzzle.
If you sit down on the side of a road on dry dirt in Australia, the bull Ants, that are the size of USA cats would have you for dinner in 30 minutes!!!I sit because it is more comfortable. If you aren't pedaling sit down find shade kinda thing. You dont have to sit. Stand beside the bike. You dont need the lock out derailleur. Move the chain off the front sprocket. It will give the exact same result. Using a dry type lubricant is beneficial but I guess that applies to all techniques. The real benefit is with the bike on its side it doesn't create the balance, movement, fork separation thing while the chain routing is obvious. When I try it upside down the chain routing is a jig saw puzzle.
A true Aussie would "will" the Ants to hold the bike stable for him while he changed the tube.If you sit down on the side of a road on dry dirt in Australia, the bull Ants, that are the size of USA cats would have you for dinner in 30 minutes!!!
Jason there two brass flanged bushes in this pivot, and the bolt/extended nut lock up with very little play, so it is designed to pivot when fully tightened up. It is a left over from the Silvio suspended front suspension. If you add a thin shim to the brass bushes it could be locked up.So I'm checking a few things on the bike wheel removal related and I just noticed my book clamp easily pivots even when totally tight on the tube. At first it seems like a normal design feature but in the Vendettas case it's allowing my from triangle to fall apart. Does everyone else's still pivot after the bolt is tight or am I the only one. Also anyone think of any reason we'd need it to freely pivot after everything is tight? I'm thinking I'll shorten the shoulder of the bolts and let it touch down and create friction so it won't move. I need to check if that'll make the clamp over tighten around the boom tube first.
Dear Ratz, my name is NOT "Crocodile Dundee"!!!A true Aussie would "will" the Ants to hold the bike stable for him while he changed the tube.
Luv that pic from last weekend. You are in front of some really good middle ga cyclists. Whooop!Oh, come on guys and gals. I go to all the trouble to make a video for you and not one solitary soul tries out the method and will come back and say "thats all screwed up or hey it worked for me!" I could have been out riding.
super slim said:bull Ants, that are the size of USA cats
complete falsehood. The minute my skewer came out, the fork and stem come apart, the axel doesn't fit back in and the tension on the chain is wrong. Be honest.Ok been thinking a lot about this lately. I have a DF friend who once said "Those bikes are nice but I heard those Cruzbikes are a bear to change a flat." It seems the bike community is eager to find fault with our prides of joy and this is only one of many myths out there . When they see the entire front triangle fall apart and the derailleur laying on the ground with a twisted beyond recognition chain I guess it doesn't help. Especially if there are three guys hovering around it scratching their rear ends. I agree any method is great if you perfect it? But geez Louize don't give the detractors any ammo. Get your system down whatever it is. I suspect I am in the top ten percent of cruzbikers with the most front flats. I have changed them in the rain, in the dark, heat, and during a state of fatigue. This is why I love tubeless and waxed chains. My experiences (yours may vary) find the lay down method as the easiest by far. Try it and you decide but whatever have a system that works for you.
The video below shows the laydown method and while not a lot of excitement the point is the ease in which the tire slides in and out without anyone having to hold or balance anything. If your loaded with a gazzilion water bottles they arent going to fall out when you flip it over nor will any of the electronic gadgets on the handlebars be in jeopardy. The only thing you have to make sure is the brake lever doesn't close when you lay it down. Hope you like the video.
Rats says I'm in the dreaded 2.5% - guess I'll never be in the majority - always available to help.My experience is 95% of roadies fix a flat with their cell phone. 50% of the remainder don't know what they are doing I know from stoping to help them. Leaving the balance reasonably competent.
...Move the chain off the front sprocket. It will [take the tension off the chain.]
Using a dry type lubricant is beneficial [...]
The real benefit is with the bike on its side it doesn't create the balance, movement, fork separation thing while the chain routing is obvious...
...derailleur in little ring on the cassette [then] wrestle with the wheel. ...
-Squareness of your front triangle
-Size of your cassette
-Derailleur arm length
-The wrap set on your b-screw I guarantee no one can remove my front wheel without dropping the derailleur because of the last three above but mostly because of the B-screw and the super short cage with a stupid strong spring.
-Those riding tubes I still highly recommend victtora pitstop. Squirt in flat wheel wait <2 minutes and pump up and ride home.
