Curbed
Joe Riel
What happens when riding a Cruzbike in the gutter and you drift into the curb? Has anyone done so? Pedal strike isn't an issue.
I rarely ride in the gutter, but a particular stretch of a main road has manhole covers in the bike lane. They are bumpy, so if there is no traffic I ride around them on the traffic side. With traffic I sometimes ride around them in the gutter. Was wondering what would happen if I drifted into the curb. I expect that the curb would prevent me from turning to the right which is necessary to initiate a lean to the left and so move away from the curb.
Ramnob42
At a guess the curb would jerk the wheel right slightly as it tries to unsuccessfully climb the curb while also slowing you down as it scrubs the side wall of the tire. The effect would be to pitch you left onto the ground.
Mind you if it happens in a left hand curve you high side (flip to the right).
Beano
I've done it once years ago on an Optima Baron here in the UK, depends on what angle you hit the kerb. hit it from a fairly wide angle and you'll scrub the tyre, coming to a stop as you scramble to keep the bike upright and putting a foot down, (what happened here on the Baron going up a steep climb).
chicorider
I recently went down on my V20c at 25mph when I failed to see a one-inch rise between the traffic lane I was in and the four-foot shoulder onto which I wanted to move to let cars pass. They were re-paving the road and hadn't yet laid down the final surface on the traffic lane that would bring it level with the shoulder. I hit that edge at a very shallow angle, it took the bike right out from under me, and I slid on my right hip and elbow for maybe 15 feet. Nothing broken, but lots of road rash and some banged-up parts. I would guess that a shallow glancing contact with a curb could have a similar effect. I totally understand your concern about traffic, but I'm not sure I'd risk it. If you go down, you could put yourself right into the traffic you are trying to avoid.
Doccus
OUCH!!!
Joe Riel
Thanks for the feedback. I sort of did the same about 40 years ago on a diamond frame, when attempting to drift up a ramp on the side of a bridge on I15 (an interstate highway). At the point I hit the ramp, there was a bigger than usual lip so highsided into a dirt area. Nothing broken. In the present situation I'm going maybe 10 mph so damage would be significantly less than your incident. However, from testing this morning, riding over the manhole cover isn't much different, jarring-wise, than riding on/off the gutter and dealing with the transition from concrete to asphalt, so will avoid the gutter.
