Electric conversion kit / Q45
AGS45!
I live in a pretty hilly part of the UK and need some throttle based assistance to help me start on hills and also to give me a bit of a boost on the steeper climbs. Has anyone had any success adding an electric motor to their Q45? If so, which one did you use?
If it's a quick release it shouldn't be much of a problem but if it's a thru axle one it's possible but very expensive. This is about the only motor I think. https://ebikes.ca/product-info/grin-products/all-axle-hub-motor.html
We have one of these (FRONT hub motor) to go on the rear of a through axle Q45 at some point at the warehouse as a test case. I am expecting no issues - other than finding a good way to mount a 20Ah battery and possibly wiring lengths. I am pretty sure this has been done on the through axle Q's before but I am not sure how documented it is (?)
My goal is to get a complete kit/orderable set put together from Grin so people can do a one-stop-shop to get a conversion - maybe with a few options that can be selected.
I am not 100% sure when we will get to that though to try it out.
AGS45!
I can’t wait to see what you come up. Good luck!
JoFlo
Has anyone looked into E-Assist from?
I have a friend who done this to his Q45 and I am currently looking into converting Q45 to E-Assist.
CruzRider
Put me down for one kit.
An electric Q45 is the holy grail of Cruzbikes - best on many dimensions
AGS45!
Yes! Enjoying my Q45-E! Longest ride so far, 52.3 miles (1477’ climbing) with an 80% charge on battery. At the end still had about 51% battery charge. Power setting 1 (power range 0-3). Average speed 14mph; max speed 33.7mph.
That looks pretty cool. What kit did you use for the ‘electric’ add-on?
bret
I liked the battery where the under seat rack is. I found that the weight on the rear rack caused too much tail wag, but it was fine between the lower rack frames and did not interfere with panniers on that rack. There are pictures of the placement in my thread.
bret
The Q45 is the 'adventure' model, and does well on gravel and off-road with adequate tires. For this reason, I preferred replacing the rear wheel (with a nominal 'front wheel' motor) as the traction is best there.
JoFlo
Still running the stock wheels with street/gravel tires. My battery is bolted on top of rear rack. Weighed the bike with a bathroom scale: front 40 lbs; rear 25 lbs. Haven’t weighed the bike with me on it - that’s next.
I added racks under the seat to allow me to add 4 panniers. The front does feel heavier when moving bike around. Haven’t really felt any wagging. I haven’t had any handling issues, bike rides good, even with cross winds. Does take a little longer to stop, so will monitoring brake pad wear.
Some have added friction wheel type kits and liked them. It was a direct install and can be removed easily. The possible issues I see with it are tire wear, friction wheel wear and especially problems with tires that aren’t relatively smooth.
