On further reflection, there's a non-destructive way to measure the thickness. Use a caliper to measure the outer diameter of the tube. Then use a stiff wire, like a section of coat hanger, and being careful to keep it straight and perpendicular to the bottle mount hole, insert it into the hole until it stops. Mark the wire as close to the opening as possible, or use your fingers as a guide. Pull out the wire and measure the distance from your fingers or mark to the end. Subtract that number from the caliper measurement and you have the wall thickness. It won't be exact but close enough that you can determine the nearest standard aluminum tube wall thickness.
