Garmin Speed & Cadence Sensor Mounting
Garmin sensor
Yes, I have a sensor on my Silvio V1.0. Not in a position to post a photo, but it's mounted on the left (leg) chainstay and the left crank arm. About 700km away from my Silvio at the moment.
I'll try and post a photo later, but there was no drama in mounting it. One of the rubber mounting blocks is relatively flat, and I used that one on the Silvio, rather than a curved one. I used a curved one on my Quest 451 :)
Both work fine.
WhiteSilvio
Garmin Sensor
Hi Jeffery,
Here are a couple of photos of my Garmin Cadence/Speed sensor mounted on the bike.
I have not included photos of the Garmin Computer unit mounted on the handlebars as my handlebars are a different arrangement to most.
Hope this helps.
Regards,
John.
PS I'm thinking you'll have already figured this all out. I've been just a little slow with the pics as I thought Dennis may have got back to his bike sooner.
GARMIN SENSOR - SNAP
Hi Jeffrey and John
I'd just finished taking photographs, when I saw John had taken essentially the same images. I've included mine - the power of numbers - to show the mounting, and for those with a Silvio V1.0, a twisted bracket that I use to mount the pulley to route the cable to the Front Derailleur.
Cheers
Dennis
