Handlebar Options v20c
The V20 and V20c bars are wide clones of the Salsa Woodchipper II bar. As on off the shelf bar it can be had in much narrower widths than the stock one (which is indeed super wide for ease of learning the bike/more casual riding)
Velocivixen
The Soma ‘Portola’ bars might be one someone could use. I’m in the process of mounting one (with SunTour ratchet bar end shifters) on my circa 1997 Rans Rocket!
Henri
scatter brain
Robert H.
I had an issue with keeping my left leg vertical to fit within the stock V20c handle bar - which I think measures about 46cm. I ended up straining my left adductor a couple of months before Bike Sebring 2024. I made the switch to a 60cm Walmer Bar W I D E Drop Handlebar to allow room for my leg to frog out a bit. They're available in 50cm, 55cm, and 60cm from an US importer called Jefe.bike. Walmer is an Australian company. They make their aluminum bars in 40cm, 43cm, 46cm as well, but you will have to order them through curvecycling.com. They have a carbon version as well in limited sizes (43cm, 46cm, and 50cm). The profile is very similar to the stock V20c handlebar.
Damien
I want to change the handlebars to something lighter and, most importantly, narrower. The standard ones are very wide, and I feel like I could even go for a 420 mm size. What do you think about this cheap one from Aliexpress? On the Cruzbike, it doesn’t need to be super durable—I don’t put my body weight on the handlebars. It’s more important that my knees have enough space and that it’s comfortable.
Handlebar from Aliexpress
