Hey Jason,With around 15 watts less your averaging about 1mph more then me. I know you weigh less then me but on a steady state ride like this I wonder how much that weight difference matters. I also wonder how much speed your track loops gain you over my open roads route where I have tight 90 deg corners and a dozen stop signs ever 14 mile lap to contend with. I guess it's a mute point since I can fathom the mental numbness required to do those tiny little laps hundreds of time.
I guess there's also you handlebar setup to factor when comparing our speeds. Every time I've tried to hold on to the flats of my bars between the hoods I nearly crash. It's crazy how all stability is lost when I try moving my hand to the center. I think rotating my hand 90degs to hold that part of the bars doesn't help ether with my bad wrists. I've considered some narrow gunners bars so I can maintain the same wrist rotation and just move my hand to center but that'll have to wait till I have more time and money.
Why tri spoke on the rear on thurs day vs a disc?
I am so bummed out on power meters right now.
I got a set of Powertap P1 pedals because my Garmin Vectors just seemed to be "off" for some reason, possibly reading lower and lower as time went by - I think because of a faulty pod.
During recent testing I was able to ride 25mph on only 170 watts - seemingly impossible on an unfaired bike of any kind - especially when a year ago it was taking me 200 watts to average 25mph.
That was also my power and speed on my open road Century a year ago, with minor hills, turns, traffic, and steady 10-12mph wind.
I did have other tests on the track here where I could do nearly 27 on about 215 with perfect conditions.
Some of my testing rides (all done with Garmin Vector Pedals:
26.2 mph for 100 miles on 196 watts on track (https://www.strava.com/activities/590900832)
24.7 mph for 100 miles on 155 watts a track (with a fall) - (https://www.strava.com/activities/356619174)
26.5 mph for 100 miles on 203 watts on a track (https://www.strava.com/activities/369589798) - my faster Century at 3:47:48 - un-assisted and carrying 5 waters bottles full of fuel and water.
26.9 mph for 60 miles on 213 watts on a track (https://www.strava.com/activities/287960236)
2 weeks ago - I get new pods, and all of a sudden my Vectors are reading 220 watts when my KICKR is reading 200 watts. Now it takes 200 watts to go 25 on the track instead of 26.5!
Something just does not add up.
Got a set of P1's and they read 184 watts when my KICKR reads 200.
So now Garmin and Powertap are 30 watts apart - 184 - 214! Both tests while KICKR is in ERG holding what it thinks is 200 watts. Collected pedal power data on a Garmin simultaneously if you wondered how.
Not sure what to make of it all.
I know, I know - many may say the it doesn't matter as long as it is consistent so you can at least train correctly, but in my limited experience it seems like the Vectors have been anything but consistent.
And now, if I take the P1's to the track - they will probably tell me I only need to push 160watts to go 25mph - craziness! haha
But back to your comments: yes, I may weight less than you (around 150), and am probably more aeor than you with my little handlebars (testing them with stock I gained about 0.5 mph), and if you are still riding disk brakes you may be loosing something there too. Handlebars: I think it is just what you get used to. I can now ride those little bars in packs at high speeds pretty comfortably, although I think I probably still do give up some control aspect.
Yes, and the track does give you faster speeds (usually ) with equivalent wattage mostly because you do not ever have to slow down and there is pretty much no climbing. I think riding on this track a compared to the open road I will gain at least 1 mph with the same wattage. If you ride an indoor track, add another 1mph. That is how Baloh (and others) can do their 8hour 200 mile rides (True be told, Baloh did that near 8 hour 200 mile during a 24 indoor track record attempt - so he could have obviously went faster)
More later - keep up the great work Jason - we are all behind you.
