In an ideal world ...
Yep,
Yep, and it's always hard not to feel like we are peeing in the pool. Don't take it that way, just pushing the envelope and adding to the knowledge base; while being happy to have a place to do it.
Let the chainstay extension be specified to position the BB.
Depending on where the Vendetta and Silvio go in the future; a few more size would be cool if you could come up with a sizing methodology. Yeah I know; I wish I could pull a methodology out of thin air too; but it seems that 50, 75, 100, 125, and 150. would really be nice to pick from; unless you have some cool adjustable one in the works.
Seem like height and waist have a lot to do with it. Too bad you cannot trust people not to be dumb. If you could, then you could ship plastic inserts that wouldn't be ride worthy but could be used for cockpit fitting so people could see which size they might like. Problem is someone would surely ride with it and hurt themselves. But perhaps this is an opportunity for bike shops to fill the void...
Let a steering tube extension be used to position the height of the handlebar clamp as dictated by required arm angle and bar choice.
Oh now the big guys will be thinking hard... Obviously you've thought long and hard on this stuff; that thought never occurred to me, but it so obvious for the bigger guys. I for one am curious what Dave finds out for really tall guys. Sooner or later he's going to get impatient and skip sleeping an do his next setup.
Let the grips on the bars be flared according to taste. Flared gives more leverage, vertical gives a tighter envelope, both can work ergonomically but I did go a for a flare on the bullhorn bars.
Now that is a great authoritative statement. And really my whole endeavor really doesn't expect you guys to solve the multitude of fit issues. But if that thought was documented somewhere in the form of "how to pick alternative handlebars" and fleshed out; that is powerful info. You obviously understand the geometry far beyond the rest of us; a technical briefing might be very useful to bike shop setup people and those customers inclined to dig in. After all, MBB still means learning -and- relearning a lot so more knowledge isn't really That probably what's attracting those of us that will dig, push and investigate. If what's known is available in written form then it takes the guess work out of rediscovering what you already know. Forums are great but man the backlog is hard to dig through; if a veteran doesn't point you at the knowledge we are often left to rediscover what is already known. I gather much of this may have been discussed before somewhere here online; hopefully the drop shoulder bars is a new idea; after all need to have some new progress.
The bullhorn bar package includes brake levers that can be mounted with the clamp near the bar end shifter - however the grip length would be too short then. When set up as designed, just the shifter lever projects out of the hand.
That one just continues to confuse me. I believe it is probably true to your design, but I don't comprehend how it is suppose to work; every photo of someone riding bullhorns shows the hand a long way from the brakes; and a brake lever that pushes the casing rather than pulling the wire. All my experience tells me that is a weakly powered brake that has to be reached for. I get why of the design, it's the ergo way. It was blastedly darn hard to work around the wire under the tape issues and the discomfort in my setups. And when it was wrong man was it obvious. I did get around it, but not yet in what I would call a repeatedly stable way, it's only tinker lab grade at this point. I keep bringing it up because it's worthy goal, not to be a pest; and I want to better understand the stock ones; which probably means I'll just buy a pair although it might be cheaper to go visit Eric for a weekend of riding.
Anyhow we'll continue to push and continue to share; it snowed again here today; stupid polar vortex.... As soon as it's warm every one will think I feel off the planet; and really we'll just be riding and riding .. can't wait and I'm sure others are thinking the same thing for different reasons.... someone shut that guy up already.. .
