Is a 2000mm brake hose long enough for the S40?
RossK
I'm planning a build on a new frameset and I have bought a used 1x road SRAM Force HRD brakeset (levers and calipers).
I know that the current fitted rear brake hose is not long enough as it's been cut short. I also know I can buy a full kit of 2000mm hose including a pre-crimped banjo for the lever end.
The question is, will 2000mm be long enough? I'm 5'7" with a 40" X-seam, so the slider and bar position will not be extreme.
I searched on the forum but didn't find a definitive answer, so thank you for any help on this!
RossK
Thanks for the reply but I don't have the frame yet. I'm just preparing parts for its arrival in a few weeks and want to know if I should buy a two metre hose kit.
If it's not long enough I'm looking at a more complex solution.
@RossK , I have a 2019 Cruzbike S40 and I use the stock SRAM Apex mechanical brake levers that came with the bike. I recently replaced the brake cable and the rear (back) wheel needed a 2000mm brake cable and it barely fit. I had shortened the brake housing by approx. 30mm or thereabouts. So, I'd say, to be really safe, get a 2100mm -2500mm cable. They are available for disc brakes intended for gravel bikes and tandems .
RossK
Thank you for the information, I appreciate it!
I'll just wait to get the frame here in Scotland and use a bit of trimmer line to measure before ordering parts!
