loose front suspension
My Quest has white logos on it with a black outline around the lettering (like Fatall's- hello!).
I am quite tall (6'5", or about 195cm), and find that I set the BB adjustment to '12,' ie, as far as it says I can put it out. When I crank hard going up hills, even with the e-ring (which I like, I guess: I don't notice it anyway and I LOVE the SRAM shifters with their intuitive shifting) distributing my cranking power better, the 'bottom bracket' noticeably bounces back and forth as the suspension 'gives.'
I think what happens here is that by changing the geometry of the front triangle, I put a lot of stress on the frame as I mash the pedals. Also, I am big and can mash pretty hard (100kg). I am sure that I lose some power when I mash up a hill as some of my cranking energy goes into squishing that front suspension. I can't imagine that the suspension delivers that power back to me in any meaningful way.
The other thing I notice is that the front suspension is easy to load to very near end of its 25mm of travel just by leaning hard on the handlebars before I get on. The worst, to me, though, is that as I go over even a small bump in the road (for some reason, it's worse at speed), then CLANK the front suspension bottoms out, if you want to call it that: in fact, the suspension can't go any further and I can hear and feel it hit the end if its travel, hard.
I have glanced through the posts above but I'll wait to see what I can do with this (or what the LBS can do, I guess, but I haven't gone there so far for any problem more major than picking up a spare tube).
So, pretty please, is there any way I can 'tighten up' the front suspension? Alternately, i guess I'd be OK to lock it in place; but I do like the suspension feature. For instructions, please be patient, type slow, and use small words. I am relatively mechanically inclined but don't know the terms for the parts. : )
Thank you for all you help with the troubleshooting!
