Here's Buddy's message with
Here's Buddy's message with links:
I cobbled all this stuff together from parts I had laying around my house, so there are bits and pieces from everywhere.
The struts (100mm and 75mm) came from the Hostel Shoppe. It's called a TerraCycle Accessory Mount. http://www.hostelshoppe.com/cgi-bin/readitem.pl?Accessory=1165594587
The bar came from Longbikes. It was out of something they call a Computer Mount. It was useful because it contained an embedded nut that allowed me to attach both struts to the bar with just a screw. You may not want to use this part, as the Longbikes Computer Mount is a little pricey ($49). I used it only because I already had it. http://www.longbikes.com/2/Parts/index.html
You could substitute with a part from Calhoun Cycles called an EVO Extension (35mm). It costs about $8. You would have to add a nut and maybe a washer on the end. http://www.calhouncycle.com/productcart/pc/viewPrd.asp?idproduct=51&idca...
The little white thing between the bike frame and the 100mm strut is a 0.25" nylon spacer. I got it at Lowe's. You could assemble without this, but things line up better with it installed.
Screws are #10-24's of either 1" or 0.75" long. M5's would also work if you prefer metric. Nuts are all nylocked.
