Thanks for the tip. I will go online and check them out. Have you been touring on your Q45?I am using Vaude Aqua Back. According to manufacturer's info: Weight: 970 g Volume: 24 l Dimensions: 37 x 33 x 19 cm Max. load weight: 12 kg
Very good quality and water proof. Except that the inside pocket for water bladder broke at the hems after some months of use.
FYI, I believe the stats listed above are for a single Vaude Aqua Back pannier, rather than a pair of bags.I am using Vaude Aqua Back. According to manufacturer's info: Weight: 970 g Volume: 24 l Dimensions: 37 x 33 x 19 cm Max. load weight: 12 kg
Capt_mc, do you have a sense of how big of big bags you're looking for? The largest panniers I'm aware of for recumbents will be bags made specifically for recumbents. For example, Ortlieb's recumbent panniers are 72 liters for the pair, extremely rugged, waterproof, heavy and expensive. Similar giant-sized recumbent panniers are available from Radical Designs and slightly smaller ones (60L?) from Arkel.
-Jack
