I think I'm one of the more recent people to try and solve this. For only 25lbs, definitely think about a seatpost mounted one. They go up to 25kg in some cases (Blackburn, Rixon&Kaul, Topeak...)
For a more traditional approach, mine isn't ideal, but it works. Ideally I'd like longer upper stays so they could be P-clipped to the top of the lower triangle.
View media item 203View media item 202
Another option is to replace the suspension with solid rod, and then you can clamp the upper stays to the seatpost.
Finally; I never figured out a rack for underseat use, but I did bodge a 2-bag method if they balance each other. The straps drape over the horizontal bar supporting the seat. Once hooked on they were pretty secure but they do clatter about a bit.
View media item 201
