Max. Tire size V20(c)
Henri
scatter brain
Somewhere around 32~35 can fit. Depends. Tire width is about as vague as shoe sizes. Also depends in the rim width. But you might prefere more clearance between tire and frame or be okay with less. And theres a few mm difference between front and rear.
Comes with 28.
chicorider
I am running 32mm Schwalbe Pro Ones on rims with 25mm internal width (pretty wide). I like 'em a lot. There is room to go up to 35mm in the front, but that could be a little tight in the back. I have about a 2mm gap between the tire and the two brake bridges, which is enough, but I wouldn't want to get any closer. Those wanting a little more comfort on their V20c could do a 35mm up front and a 32mm in the back.
