Jim Zimmerman
The problem has been solved, mostly. In this first photo from the rear of the upright bike, you can see the entire brake caliper with the rotor on edge. There is a gap on the right side of the rotor which is more obvious in the close-up.
The adjustment for the right side brake pad is the large red "button" looking screw pictured below.
I turned it tighter, until the rotor began to rub on the brake pad. That reduced the amount of "bend" in the rotor when the caliper squeezed on it, but it made the grabbing even worse. I followed the instructions posted by Super Slim above, loosening the caliper mounting bolts, squeezing and holding the brake lever while tightening the caliper mounting bolts. That centered the caliper on the rotor but I had to back out the red adjusting screw and re-center the caliper so the rotor didn't rub on one side or the other. The rotor was obviously not straight with the wheel.
That's when I went to the LBS and asked for advice. The mechanic told me the hub bolts will self-center the rotor so there isn't anything I can do about the rotor being non-concentric. Regarding the wobble from side to side, he offered two options. 1. He can try to straighten out the rotor. 2. He can sell me some new rotors. The cost was about the same either way but the non-concentric problem would not be cured by option #1.
I bought a pair of Shimano 160 mm rotors and brought them home to assemble.
After installing the new rotor (this is on the rear wheel only) I examined it closely both for wobble and whether it was concentric. It was concentric but the wobble was just as bad as before. I am therefore concluding that the rotor mounting base is not straight to the rest of the wheel.
Fortunately the kit for the new rotor came with some shims. I'm not sure why they were there but I decided to use them to "straighten" the rotor. Each shim spans two bolts. Multiple assemblies later I came up with the combination pictured below. Two shims are overlapping and another is isolated.
I re-centered the caliper and then set the red adjustment screw to just barely touch the rotor, to determine that it contacts on and off around about 3/4 revolution of the wheel. Then I backed it out until it doesn't contact at all and left it that way.
After testing on the street I have decided it is acceptable. Braking is not perfect but it doesn't lock up the rear wheel any more. The photo below shows the odd location of the shims, and BTW you can see the wear patch on the rotor, how it doesn't quite align with the intended friction rim. I checked the original Clarks rotor and its wear pattern is also in the wrong place.
Now that I have concluded my adjustment to the rear brake I took a look at the front brake. While sitting on the bicycle seat I could see right away that one of the rotor mounting bolts was unscrewed about four turns. I tightened up all six (all were loose) and set the torque to 5 newton-meters (nearly as hard as I can turn my T25 Torx screwdriver). This rotor was also non-concentric but it didn't seem to have as much wobble as I had seen on the rear rotor. I tested the front brake on the street and concluded that it was acceptable as well.
SUMMARY
My problem with the rear brake is the rotor mounting base on the wheel's hub is not aligned with the wheel, requiring shims between the mounting base and the rotor. I did not need to buy a new rotor but I may want a new wheel. My problem with the front brake was loose rotor mounting bolts. I should have checked them when assembling the bicycle in the beginning.
SUMMARY
