Bob, on the Schwalbe website they claim a 5.5watt saving in going from Ultremo ZX to ONE Tubeless!
Have you noticed the difference, and would 5.5 W be measurable with a power meter while pedaling?
We have 6 Tier 2 TRI guys in my city area they live our here to have access to the windy training roads; and 4 CRIT racers. of those 9 guys and 1 gal, 7 have made the change to the One's and the word is they aren't going back. Only 2 are riding tubeless; and are on year 2 of tubeless and very happy. We are running Bontrager's tubeless system so we still have Bontrager TLR3 and TLR4 rubber on the road. When those wear out the One's will get a go; because the TLR4 is pricey and hard to get at times even if Trek is only 4 hours from here. Also point to remember is we are testing stuff these year for when it matters in coming years. So if you find anything else that should be test tell me to put it on the list; we'll get to it eventually if it has merit for our plans.
Here's my thoughts on the state of tubeless.
- If you suck at changing inner tubes stop here tubeless isn't for you.
- If you are great at changing inner tubes remember back to how long it took you to be great, and continue this list.
- Have you ever successfully patched an inner tube and then ridden that tire for 100's of miles? If yes continue, If no because you are too awesome at #2 to bother patching continue ; if it's too much work to patch a tire, stop here tubeless isn't for you.
- Do you refuse to carry a spare inner tube because it's too much weight; stop tubeless isn't for you.
- Do you carry a entire spare tire with you on rides over 100 miles, continue tubeless is for you.
- Are you willing to spend two days in the garage cussing while you learn, then continue.
So why do it?
- No pinch flats running lower pressure so you can get optimal rolling resistance
- Tiny spike punchers like glass, thrushes, goat heads, and small nails; self seal while riding; bigger cuts seal after you stop an wait a minute or two; then just pump back up.
- lower pressure mean smoother ride on chipseal
- No inner tube rot on your spares inventory
- No high impact blow outs; but you can still dent a rim nicely.
- Tires don't blow off the wheels; most flat deflate slowly and leave you in control of the bike;
For point of reference both Silvios' are tubeless; and the Vendetta is tubeless; the Quest are tubes and will remain tubes forever just no point there to bother with it not enough gain.
if competing at any event when possible I'm still going to have spare wheels and a spare bike ready to go; changing wheels or bikes is still always going to be faster.
Lastly if you are turning a mag trainer; the Durano Skid is still the best tire; that thing was build for a FIXIE and it holds up better. See Lief for the facts of running the wrong tire at the wrong pressure on the mag trainer.
