Andrew Wilson
Looking for first hand opinions on this: https://cruzbike.com/collections/all-products/products/suspension-adjustable-headrest
Considering buying one soon.
Thanks
Thanks
Thank you. Does it hold up well ?I use that headrest. I do mod it a little. I cut down the size of the headrest plastic piece and change out the cushioning. It works for me.
I have it on my S40 with Thor seat. Works well.Looking for first hand opinions on this: https://cruzbike.com/collections/all-products/products/suspension-adjustable-headrest
Thanks
It does for me. I am a lightweight. I have used the same one for several years.Thank you. Does it hold up well ?
I used it for quite some time. Very pleased. Eventually the screws loosened up to where I had to replace, but that was an easy fix. It now resides on my S40.Does it hold up well ?
That's what I said to myself too!Installed and went on ride today....Why oh Why did I wait this long. Really makes a difference on chip seal and crappy roads.
Hi @Robertas your bike looks so awesome and stealthy. Probably you took the Banana Racers in orange, so that you do not immediately run over?I have installed mine too, it works really very well. Much more positions available.
Hi Andreas,Hi @Robertas your bike looks so awesome and stealthy. Probably you took the Banana Racers in orange, so that you do not immediately run over?
Your photo gives me some new ideas for my Brevet setup.
Are these fenders SKS Bluemels 35mm wide glossy (not matte)?
Any issues getting them installed in the front (fork and main frame clearance)?
What tire size do you have?
I currently run tubed Conti 5000 28mm wide and I think that there is not much clearance under the front fork so i was looking for splitted fenders like these but when installing the rear fender in the front, the split is in the wrong position:
.View attachment 14921
And your fenders are still alive?
I'm asking because I had Bluemels 45mm wide on my trike and they broke after a few months.
