Original dimension Drop bar on S40
Bixente
Hi,
I'm french, I have a 2017 S40 that I bought second-hand.
The previous owner cut the drop-bar. I would like to put the original drop-bar.
Which drop-bar should I choose please?
For exemple, Salsa Cowshipper Deluxe is it compatible (46cm width, 116 mm drop, 68 mm reach, 24° flare angle, 12° drop angle) ?
Many thanks.
Best regards
Bixente
chicorider
Hello Bixente,
Many riders use and like the Cowchipper. While I don't use it myself, I have heard that it is fairly similar to the original Cruzbike bar.
I use the Genetic Digest Flared Drop Bar (yeah, I don't understand the weird brand name either, but I like the bar). It comes in a 44cm and 48cm width. I use the 44. Here's are a couple of links...
Bixente
Hi Chicorider,
Thank you for taking the time to answer me. I don't know the Genetic, I'll look into it in detail.
For the Cowchipper, I've already had one on another bike, I was very happy with it.
I'll see you my next set up.
Bixente
chicorider
You would probably be happy either way. Here are a few pics of the Genetic bars on my bikes...
Heads up for new S40 gars - the stock bars are just a 2cm wider clone of the largest stock Salsa Woodchipper II bar - in case you were looking for a comparable to compare against.
