Flying Dutchman
Hi,
I've become the lucky owner of a nearly new Q45 (model 2022) and am really enjoying learning to ride recumbent. I've been riding traditional bikes for more than 55 years and done all the maintenance including full bike builds myself for many years.
Like I said I am very happy with the Q45 apart from one thing and that is the shifting and I am wondering if anybody else has the same problems and/or any solutions.
The issue is that when I shift (up or down) it is very inconsistent. Sometimes it shifts 2, sometimes 1, sometimes none. It hardly ever shifts into the smallest ring but sometimes it even 'over-shifts' causing the chain to come off (had that twice yesterday). After shifting, it tends to make chain noise clearly indicating that it is in the wrong gear. Nudging the lever a bit makes it then go into the right gear.
Having done mechanics on bikes for many years, I've adjusted the cable tension up and down, adjusted the stoppers as per the instructions etc etc. When I put the bike on a work stand, the shifting is spot on, but as soon as there is tension, the gears 'stick' and misbehave.
I don't think there's any 'play' in the derailleur itself, however the jockey wheel of course has to have some play in it. Could it be that there's too much play in the jockey wheel? Or should I look in other areas? I can't imagine it's the cable. I also don't think the chain could cause this. Looking at the rest of the bike, I don't think the previous owner did too many miles on it so I can't imagine wear and tear coming into it.
Any other suggestions? I'm seriously considering ripping the Microshift stuff off and replacing it with Sram as their mountainbike stuff is pretty bullet proof.
Thanks
Thanks
