(Also re
@ratz message above "The air shock is from ali express is a "Kind Shock A5-RR1" that's the one everyone used to upgrade the Quest V1, V2. I do not know for certain it fits the newer Q45 but I think it should". [Yes, it does, but see below])
I mounted a new 165mm A5-RR1 on my Q45 yesterday. I have only a bit of test-riding experience with it, quick tests on a local extremely bumpy stretch. The difference seems similar to what I previously found for this shock on my Q559 (see many comments on that in this forum; try searching A5-RR1). Looks like a major upgrade. I'll comment again when I've put some miles on it.
I paid $74.96 including shipping (from Hong Kong, I think). I ordered it on Sep 12, from bidnow4u2008 on ebay, and it arrived Oct 2 by regular postal mail. No faster shipping option, as far as I could see.
- It is way, way, lighter than the stock spring shock. I was ... shocked ... to take off the spring shock and feel its weight! It's a brick! I only have a kitchen scale up to one pound and this clunked right to the bottom of that. Whereas the air shock is about 1/2 pound. The weight alone is enough reason to get this.
- They have changed the locations of the air-filler holes so both are accessible without unscrewing the shock. On the other hand, my previous experience was that this shock holds air for months and many 100s of miles, so a bit of unscrewing is a minor annoyance.
- The fit is _very_ tight, especially at the bottom (swingarm) end. Did I say "very"? This is especially true since the sleeve-bolt fits exactly through the mounting hole in the shock, thus they must be perfectly lined up. Doing that when moving the position is extremely tight was not easy. A rubber mallet, gently used, was helpful [edit: to tap the shock into position, not to force the sleeve in!]. I put some Phil Wood grease on the mounting surfaces; hope it doesn't squeak.
- I mounted the top end with the included sleeve nuts rather than the CB quick-release, see photo. (In my opinion, CB goes overboard on quick-releases, especially for things like this that do not get taken off often). I noticed that the QR shaft was slightly smaller than the mounting hole in the shock, resulting in some wiggle when it's not loaded. The sleeve-nut fit was exact; so exact that the paint on the inside of the drilled mounting holes on the frame needed a bit of light sanding for the sleeve to fit.
- Definitely get the dual-chamber version. Otherwise there is lots of rebound bouncing.
- It is adjustable by changing the air pressure. I weigh 180 and used 150 for the main and 125 for the negative on my Q559. I started out with those values here and might go up. Of course you need a shock pump (about $25). Though in fact it holds air so well you could probably get by pumping it up occasionally at your LBS.
- Note the rubber o-ring around the piston. That shows you your maximum compression. I like it to be about halfway down the shaft. That will help you choose your pressure.
- Don't mix up the filler caps! One is marked MP for main chamber, the other NP for negative. There is no other way to tell which is which. The negative chamber must be lower pressure than the main.
