billyk
Hmmm ... I'm no engineer but I do believe the formula is right (I'm a physicist - fluid dynamics). Your G is for 7505-T6 aluminum, right?
Another solution would be to move the joint at node 2 up to right under the handlebar (reducing L to near-zero in your toolbox above). There would need to be another clamp at the top of the headset to hold that together. However, this would also lengthen the boom/extension tube, which would worsen its ability to withstand bending.
How much? How did you model the fact that the extension tube is clamped into the boom for 2-3 inches? And do you allow any flex in the joint at node 2?
I can't lower the handlebars without hitting my knees.
But, yes, I think it IS worth increasing the stiffness of the front end. My test rig (described at the top of this thread) shows significant bending under real-world high load. In fact I can see this by eye. That means part of the work I'm doing is going to bending metal rather than forward motion. The fact that this occurs precisely at the time when I'm working hardest - going uphill - makes it more important. It hardly matters for a nice cruise on flat ground, but climbing is where recumbents typically lose out to uprights, and the Cruzbikes have a potentially big advantage.
I don't have a Silvio or Vendetta to test but I'm also surprised to hear that the difference is only 15%. Lots of people on this forum ride both Qs and S/Vs, and they report much better hill-climbing.
It would be pretty easy to test the twist in the steering tube: just attach clamps top and bottom, with needles to nearly touch in the middle. Any relative motion of the needles would be visible.
Billy K
Billy K
