QX100 renovation, Emeljay mod?
devonian
Hi all!
I have a QX100 that I've been working on for a few months in an attempt to turn it into a road bike instead of a mountain bike. I've gotten new tires, new brake calipers, new brakes and shifters, and new (used) handlebars. It's much more road-styled now, and works better, but I've just realized that you can also turn the rear support tube around to massively lower the seat angle. At the lowest point, in fact, it's at about the same angle as my V20 - which is so much better than I ever expected. It raises a bit of an issue, though, because if I keep it at that low angle, the handlebars are completely inaccessible! I've looked into longer stems, but 150mm seems like the maximum readily available - which would help, but definitely not enough. So, I'm curious about doing an Emeljay mod on it to make it more or less a Vendetta with suspension. Does anyone know if the stem used on the non-T50 modern bikes (like the one used on the V20 to connect the steerer tube and the boom) is compatible with the QX100 steerer tube, and if so, does Cruzbike sell those parts separately? It'd be awesome to just assemble a front end rather than having to custom fabricate it as others have done before. In addition, has anyone mounted a standard headrest of any sort to the back of the QX100/Q45 seat? It definitely needs one at this angle, lol! Any kind of suggestions would be appreciated; making a Vendetta with actual suspension is well worth most costs. Touring on a racing-style, suspension-equipped Cruzbike would be AWESOME.
Omieone
Following your build as I'm looking to make the Q45 a little quicker, you said you changed your tires did you upgrade to 700 rims?
devonian
Nope, just the tires - on the QX100 at least, going up a size in wheels would make the clearances no longer work at all for me (I'm 6'2"). Not sure how that would translate to a Q45 though; I'm sure a good bit of the frame design changed between iterations.
kizarmynot
I’ve used 700c wheels on my 2024 Q. I was running 700x32 (that’s what I had) but it bigger tires will fit (up to 40?). Another option is replacing the shock with a metal bar. You’ll find a discussion about that elsewhere. There was a concern expressed about long term fatigue, but I can’t speak to that.
Omieone
Did you notice any difference in handling or speed with the upgrade?
kizarmynot
Not really. Biggest reason for the switch was running tubeless. FWIW, the biggest improvement for me came with moving to an S40.
