Replace Q45 Shock with Metal Bar
Black Hawk Down
Senior Rookie
How is the comfort level? I have a Thor seat with just the basic mesh pad. Thinking about a swappable soloution using the bar for road riding and a heavy coil shock for touring.
For me, the shock did softened large bumps but with the bar, it still seems like a pretty soft ride.
I would check to make sure your "heavy duty shock" will not bottom out when you have a full touring load and going over a bumpy road. I haven't found any shocks that would work for my load.
Thanks for the response. I’m a newbie to recumbents, I got my q45 and had fewer than 50 miles on it - mostly neighborhood riding to learn how to ride it. Then just finished a 260 coast to coast tour of Florida.
Before I abandon the idea of the air shock, a friend recommended that I move away from the knock-off variety shocks and find either a Fox or Rockshox with a true lockout. They aren’t cheap. I found this one on Amazon:
But need to confirm there is clearance for the width. Has anyone tried this level of shock replacement?
Black Hawk Down
Senior Rookie
I looked at them but decided that they wouldn't work for me due to my weight.
As far as fit, my shock was 165 mm in length with 24 mm bushing length with an ID of 8 mm. Looking at the one you chose on Amazon,
(165 x 38/6.5 x 1.5)
I'm not sure what all that means, but it doesn't look like the right bushing length. The good news is that if you are an Amazon Prime member, you get free returns so if it doesn't fit, just return it.
vmi1056
Did you ride the Florida C2C linked trails? That tour is on my list. I hear there are three options for the gap in the trail, one being mostly off road for 50ish miles.
I did finish the C2C ride. I’m a Floridian so I love Florida. It’s a great winter ride to get some miles in. However, There are several long sections that are just battling traffic and crosswalks across 6 to 10 lane intersections. The bike did ok but I’m very disappointed that there is no shock absorber that won’t bottom out. I’m not that heavy (I weigh 190 plus 25 pounds of gear on the back). As far as the hwy50 gap - it’s no problem. Check out Ed Cycles on YouTube. He figured out a route on backroads - which turned out to be one of the more enjoyable sections.
Updating my own post. I splurged and bought - what I was told was - the best shock available - a Rockshox Monarch RL which was nearly $300 with the mount fittings. It has a “lockout” which I thought would be my solution to bottoming out in the hills. It turns out, at full pressure of 275psi the shock is mushy when the lockout is off, and when it is on (locked out) the bike almost bottoms out with my gear - in my neighborhood. So it wouldn’t be usable for hilly touring or bumpy trails. Soooooo disappointed. Is this a design flaw in the geometry of the bike? Why sell a touring rack if it won’t tour. I’m going to look at the Azub and ask for an upgrade for my birthday :)
