Road disc calipers on T50 post mount
Rampa
So I am facing an issue that maybe someone can help with. My T50 is set up with regular old mountain bike disc brake callipers. So these calipers expect a 15mm cable pull. I am testing out using some Sensah SRX Pro brifters. Since they are road/gravel (for drop bars) they have a road brake cable-pull, which seems to be 8mm.
I am looking for a good solution to use road callipers on a T50 frame and fork. I did find the post to flat adapters plates for mounting. Is that all I need to make the frame road break compatible? I am hoping to stick with my existing 160mm disc rotors.
