They say 30 actuation to bed in tooI did notice that as I tightened the bolts, it pulls the entire brake back towards the outside just a bit. Visually inspecting the brakes, it is the inside pad that seems to be the bigger problem. I do have both of the pad adjustments screws backed out all the way; it I turn them even a quarter turn, the wheel spins less freely.
I am contemplating pulling the pads on the rear brake and then reseating them. As they are now, I don’t see enough of a gap for the rotor to spin freely from the pads. I will say, it feels like I am missing something easy and fundamental.
I suspect the mounts are not ‘faced’ accurately enough and so the pads my not be parallel to the rotor. They may ‘wear’ into place, I think
30 actuation, means riding up to 20 kph (13 mph) 30 times and applying the brakes to stop the bike, gently slowing down to 5 kph, then accelerate to 20 kphI’ll be honest, I have no idea what that means
I just got the vibrating brakes he mentioned after a steep descent. I need to keep an eye in this and my braking... thx for the post. I thought maybe I’d warped my rotor but it sounds like it might be this transfer thing. Never had it in all my years of mountain biking. Probably road compound pads as mentioned.30 actuation, means riding up to 20 kph (13 mph) 30 times and applying the brakes to stop the bike, gently slowing down to 5 kph, then accelerate to 20 kph
https://cyclingtips.com/2018/03/road-disc-brake-bed-in-process-end-vibrating-noise/
Yes. I will monitor. It’s not consistent. As you say it could be a variant of squeal but from the frequency and abruptness of the sound I suspect something related to the cutouts in the rotor or a deposit on the rotor. Maybe I remember a friend removing a small stone that became lodged in his car brake pad and gave rise to a similar effect. So a close inspection may be in order.Roger, I just had the a vibration sound on mine as well. Best way to explain it is as it you use a bit of water on the lip of a thin glass to make it vibrate with resonance; similar sound.
I will keep fighting with mine for a few more weeks. If I cannot get them working well, I’ll take it to the bike shop so I don’t worry about them on longer rides right now. I really want to learn how to maintain the brakes for when things go wrong on a long ride or tour.
