Sounds like the perfect use case for a road 1x setup. You mentioned that you "did not even notice the slight larger gaps in the middle gears from this change". Did adding the Wolftooth cassette expander with 49T large cog affect the middle cogs at all?Doesn't it just slot in at the back of the cassette?
-Jack
Raleigh, NC
Hi Jack,
The Wolf Kit takes the Shimano 11-42T cassette and replaces the 17T and 19T cassette gears with an 18T gear, which then makes room to add the 49T granny gear. Its bigger than my 160mm front disc brake rotor!
So the spacing changes from stock: 11, 13, 15, 17, 19, 21, 24, 28, 32, 37, 42
to Wolf kit modified gearing: 11, 13, 15, 18, 21, 24, 28, 32, 37, 42, 49
So just a little wider spacing in the middle, like I mentioned.
P.S. I had to take one of my tubeless tires to the LBS also to get it seated, no issues getting them on the rim, but could not seat them without a compressor. They are Michelin Protek Urban tubeless tires.
