Decher Kritzmire
After about 600 miles and too much time personalizing (mostly the seat) I think I have this dialed in and worthy of sharing in the event that there's any take aways for someone else.
Brief background: 62 years old, 20 on recumbents mostly high racers of various brands. The development of cervical stenosis has made the reclining seat and forward neck curvature uncomfortable. While I could raise the seat on my previous Metabike the high bottom bracket created a closed hip angle unfriendly to my arthritic hips. Isn't aging fun. My goal was to have a high racer style bike with upright seat and lower bottom bracket to open and elongate the hip angle. The S40 looked promising due to the downward rotating boom adjustment. I have fairly long legs and estimated that the resulting BB height would be good.
Build points: This is a 2x9 set-up:
DaVinci crank arms, 160mm, 110/74 spider set up as double with TA Zephyr 44t middle ring and 27t Rotor Q inner ring, 11-34 cassette w/ XTR der
Microshift thumb shifters, front is friction
Soma Gator bar
Shimano Tiagra flat bar road brake levers with TRP Spyre brakes
White Industries CLD hubs on Velocity Dyad rims
Origin8 steer tube extender cut to desired length
Thor seat and Ventisit pad (thanks to another forum member for the sale) - I spent a lot of time (as many of you did) trying to get the seating comfortable, not too reclined for the neck, not too upright for the lower back and recumbutt, etc, etc. The curvature of the Thor seat was much better than the stock seat but the depth of the contour felt excessive. I wasted a bunch of scrap foam sleeping bag and yoga pads adding and subtracting layers to change the contour until I reached one I could comfortably live with. Actually, its really pretty darn good. I'll post the seat mounting system I used in a second reply.
Soma Gator bar
