mzweili
http://ademhr.com/index.htmlwhere to buy??
Is all this aditional support rubber needed? I would like to support seat only at 2 places.The shape of the seat isn't going to match the shape of the frame at all really. Your likely only going to have surface contact at your two mounting points and maybe the middle somewhere depending on how low you mount it so here's a suggestion. After you get the seat mounted un-mount it and make a note of where the frame material is solid, so in between the hole cutouts. Now mark 3-4 points on the new seat where you could add a rubber support piece between the seat and frame without it falling over one of those big holes. Now remount the seat and using a small 1/8" drill bit drill one hole at each point you wish to add support. Now with the holes drilled take a small rod or the 1/8" drill bit and drop it into the hole and get a measurement between the seat and frame. Make notes of each measurement on the seat then cut the appropriate thickness of rubber for each spot and glue it to the frame. Now you have support at 5-6 points along the full length of the frame. I think I have 4 added support points using this method and they measure 4, 6, 17 & 19mm thick.
The hard shell seat is designed with the two outer rib supports and only require two mounts fore and aft. However, you can have as many as you want. The intention of the seat is to suspend the mid area between the two supports which gives a little suspension. As Jason mentioned, the seats do not follow the exact contours of the frame.Is all this aditional support rubber needed? I would like to support seat only at 2 places.
Because I would like to use antivibration bobbins I need connected surfaces to be as parallel as possible to avoid unecessary tension in rubber. And this happens ~15 - 20 cm from end of frame.
That make sense. You have probubly much better roads. My power is meybe one third lower than yours, I am lighter and also I don't win century races. So what is luxury car suspension for you may be sport car suspension for me.Needed? Probably not since I doubt many others have gone to the trouble. If your trying to build a soft luxury car that is going to have some body roll then two soft points of attachment should be fine. My setup is a nice solid anti vibration race car with zero body roll to help with sharp cornering.
A little vertical flex is okay and should only come into play when you hit bumps or uneven surfaces. This is part of the intentions of the seat.I have fitted my new seat. No photos yet. First ride shown that seat mount is flexing as I pedal so some support under lower back will be needed. So @RojoRacing thanks for advice. Without it I would not put my hand between seat and frame and sense ~3 mm movement.
Flex is from pedaling and it is horizontal. I can feel that V in this configuration is not as responsive as it was with seat directly supported by frame. So I will add hard rubber support under lower back.A little vertical flex is okay and should only come into play when you hit bumps or uneven surfaces. This is part of the intentions of the seat.
I am experiencing ride soreness and post ride stiffness of upper part of my glueus muscles group.I don't know what recumbent butt is so do you mind clarifying? The only issue I experienced and only once was some serious chaffing of my hamstrings from the very front of the seats edge. What happened was the ventist pad was too long and having just that extra 1" of pad sticking past the seat edge was enough to interfere with my legs. I didn't notice the issues until many hours into my ride but by that time the damage was done. I adjusted the pad back an inch and the problem has never come back.
Can you take a picture of you on the seat with with your leg fully extended? As we discussed in other threads, you don't want contact with your upper thigh and the seat when fully extended. Even the pad bouncing against that area will cause the glutes to burn after awhile.I am experiencing ride soreness and post ride stiffness of upper part of my glueus muscles group.
Vendetta seat was like miracle after riding years with sore butt.
I will lower upper support to 10 mm and if necessary to 5 mm.
Not now. But I know soreness from contact of tights with seat edge and this is different. I have mounted seat as back as possible. Screws are ~6 cm from seat edge.Can you take a picture of you on the seat with with your leg fully extended? As we discussed in other threads, you don't want contact with your upper thigh and the seat when fully extended. Even the pad bouncing against that area will cause the glutes to burn after awhile.
