Dave, My sight line is above the straight section of the handle bar and I can see above and look slightly down on the top of the slider and boom. So OK there. You don't see the road real close to the front wheel but near enough at the speeds the V20 is designed to maintain IMHO.
I plan to evaluate the V20 with the new Midge bar and adjustments for a couple of months. If I still want my hands lower, I may spring for the curved slider later. I actually have the bar quite high on the Silvio 1.5 as I must have it there to clear the tops of my legs. Otherwise I would have lowered the handlebar on the Silvio. I still have more than enough top leg clearance on the V20, though lowering the bar by 40mm might get it very near the tops of my legs. I would need to verify if I have at least 40mm clearance before buying the curved slider.
Do you use a water bottle mounted using the cage bolts in the curved slider on your V20? If so, it is hard to get the bottle in and out of the cage? Thanks.
Have you cut down your fork yet so only the 1 thing spacer is used? I find for a guys build that's the best first step; then if you need more the curved slider. Example my bike cut fork; straight boom. Wife's cut fork curved boom. I tried curved boom uncut fork and it wasn't as good as cut for straight boom for me. Granted I got to test using the wife's cut fork but you should be able to simulated the setup by offsetting the boom to the right of the fork and lower it.
