Nope BSA 68 English. Which gives the widest compatibility with cranks. Personally I think you'll find all the other standard are oem lock-ins or attempts to compensate for carbon composite problems.Has the BB type changed to a 30 mm crank BB386 EVO, with a 56 mm OD BB shell 87 mm wide, and press fit bearings 42*30*7 6806-2rs, with a 2 mm thick nylon sleeve and the bearing outer face at 87 mm???
The big win here is all shimano hollowtech, SRAM gxp, external bearing bb30, and square taper work
