Thor Seat
cruzKurt
Looking for some info from anyone that has a Thor seat on a v20, v20c or maybe an s40. Specific model you have and pics would be great!
Large Sport G with Ventisit. With ICE headrest.
Mine’s bolted only at the lower front wings, with some thermoplastic and Velcro.
I would suggest an extra large for you, the large is about the size of Cruzbike’s Adjustable Carbon Fiber Seat and Headrest at its maximum length setting.
I have an Easy Seat Carbon on my S40. There’s a slight difference up front that I think makes the more upright position work better.
cruzKurt
Thanks, I do like the XL, and I guess this confirms the sport G is the correct one.
cpml123
It supports the body, especially the shoulder, much better. I feel I could ride the bike more easily and better power input.
My build:
Did you go with the carbon seat due to weight difference or some other reason? I’m considering one for my Q
cruzKurt
My build:
Thanks for sharing, I guess for the v20 I should go with the Sport Easy, probably go with XL. I also have a SRAM red system I plan on using, need to find a cassette that is compatible with the wide range red etap AXS.
Wider and rounder seat area, better shoulder support.
I should have been clearer. Did you choose the carbon Thor seat over the fiberglass Thor seat due to weight savings or something else? I’m assuming both are shaped the same way, but if the carbon seat provides more support than the fiberglass then that would be great to know.
