dule0911
@velocio
Thanks for the links. Knew about the site, but forgot to check it. By looking at Daves photos and description, a 5000 700x32 should barely fit - it's 1mm taller then the 4000 700x28. Not sure if 0.5-1mm of clearance would be enough though - since he mentioned that a 1.5mm alen can fit between the tire and fork, I'm guessing that the distance to the fork is 2mm max with the 4000 700x28.
I'm also considering the Vittoria Corsa Control G2.0 Folding 30-622. Didn't find the 30 width in some review, but they should fit if the 25 review is anything to go by, since they are about a mm lower then the comparable conti GP4000S II 25C.
