Here is a poor man's cruzbike. The parameters are taken from my DF road bike: head tube angle 72 degrees, trail 70 mm, wheel base 1040 mm. The back rest angle is 34 degrees.
The rear wheel is an old 36-spoke wheel with 32 mm tire. The front derailleur hanger is a standard one; The center of the slot to the center of BB is 145 mm, and the angle of the stalk is 63 degrees ( 65 degrees if you want to use 3-piece chain ring). The drive train is Microshift Centos 11; it has two shifting levers. I tried both standard (53/39) and compact (50/34) chain rings, all worked very smoothly.
Don't ask me the bike weight because I don't have a accurate scale, on bath room scale, it shows a little bit over 10 Kg.
Very nice @dtseng !
Correction, though, a Ti frame does not qualify as a "poor man's" bike
